- Newton
- Apr 2, 2020
- East Bay Area, CA
- p̶r̶i̶u̶s̶ c̶,̶ y̶o̶t̶a̶ p̶i̶c̶k̶u̶p, ⼕丫⻏🝗尺セ尺ㄩ⼕长
I have been wondering a couple things, mostly how hot the CT will get in direct sun all day. (Also just thought of will it elongate or do temps need to be higher for that?)
UPDATE
12x12inch plate in sun for about 3-4 HOURS @ about 85F outside temp...
stock finish getting to about 150F
mirrored seems to be almost always 10-15 degrees cooler than the stock finish
the black vynl covered is getting up to 163F
the white vynl is about 40F cooler than the back
Any thing else y'all would like to have tested?
Of course this is just for fun and a bit of info. we don't know the alloy or if its heat treated,or do we? Elon does say "ultra hard 30x steel"
I guess I'll get a hardened sample to test, depending on what I can find (Unless some1 wants to let me in on the secret Sauce. I wont tell)
7/21/2020 looks like its a 304L basically the same as what im testing (but still dont know if its hardened)
1st test is showing:
After 1 hour in direct sun, no wind ambient temp about 85F on 12x12" 304 stainless
Mirrored finish is 128F brushed finished #4 sitting at 138F
Using a better thermocouple/thermometer than the 1st test. ...
2nd test mirrored and flat finishes after all day in the sun ambient temp 78f very slight breeze.
Mirrored : measured under the plate with k type thermocouple taped to it. 120f
Flat : on top (facing sun) 130.1 f
Under 129.4 f
some1 asked about magnitism- Its basically non existant, super strong neodymium can barely hold itself on
New surface temp test with vyln wrap tape type material on it. ( i figured painting wasnt really relevent.
Pic should be self explanatory but ill write the cliff notes here.
ambient temp about 80F
-White coolest 30-40F cooler than black
-mirrored next coolest
-unfinished surface 2nd hottest
-Black hottest
@ 10 minutes in sun: unfinished surface: 112.1F
Mirrored: 108.5F
Black vynl: 132.3F
White vynl: 101.8F
@30 minutes unfinished surface: 123.6F
Mirrored: 116.4F
Black vynl: 141.4F
White vynl: 112.1F
@50 minutes Unfinished: 124F
Mirrored: 120.7F
Black Vynl: 148.5F
White vynl: 108.3F
Ill do some 1 on 1 tests: 1 plate all black vs 1 plate all unfinished.
I think having the colors on 1 plate eventually (past 1 hour), started effecting the other temps. also will leave for 3+ hour to try an find a max temp
did a little tempering color test
UPDATE
Under 129.4 f
-Black hottest
Mirrored: 108.5F
Black vynl: 132.3F
White vynl: 101.8F
Mirrored: 116.4F
Black vynl: 141.4F
White vynl: 112.1F
Mirrored: 120.7F
Black Vynl: 148.5F
White vynl: 108.3F
