hridge2020
- Henry
- Dec 4, 2019
- Central Coast CA
- Tesla
Hello,
Have some information on the TeraFactory build schedule.
Telsa is sourcing out vendors/contractors to bid on work at the site.
Drum roll please on estimated on First Substantial Completion --
( Substantial completion is the stage when a construction project is deemed sufficiently completed to the point where the owner can use it for its intended purpose. This definition of substantial completion is based on the language in the American Institute of Architects form contract AIA A-201: )
Here’s a brief list of common terms that are used regarding completion:
May 1, 2021
*************** Update*********
I looked up the construction term dry-in.
I don't think there is an industry-established consensus definition of "dry-in;" it is whatever the Design Team defines it as in the Contract Documents.
ARCOM MasterSpec provides the following definition in their Section 01 50 00 - Temporary Facilities:
"A. Permanent Enclosure: As determined by Architect, permanent or temporary roofing is complete, insulated, and weathertight; exterior walls are insulated and weathertight; and all openings are closed with permanent construction or substantial temporary closures."
Regarding the drywall installation, we have a provision in our specifications that requires the contractor to use GP's DensArmour Plus for all "Interior partitions where Contractor desires to install gypsum board prior to building dry-in."
We also stipulate that any gypsum board that gets wet, for any reason (i.e. roof leak, water pipe leak, spill, etc.), shall be completely removed and replaced with new material. No other options will be entertained. The potential risk for mold is simply too high. "
[ATTACH type="full" alt="CYBERTRUCK FACTORY ACCESS.png"]3263[/ATTACH]
[ATTACH type="full" alt="Project Schedule.png"]3258[/ATTACH][ATTACH type="full" alt="Prelimnary Schedule of contractors.png"]3259[/ATTACH][ATTACH type="full" alt="Project OverView.png"]3260[/ATTACH]
- Partial completion
- Sectional completion
- Substantial completion
- Final completion
- Certificate of occupancy
- Contract’s completion date
May 1, 2021
