- Reginald
- Oct 1, 2020
- Kirkland WA USA
- Toyota Sienna
- Private Lending Educator
It is kind of an edge case yes. But if hydroelectric equipment was small and portable it could be an interesting case.You are bring up a real corner case:
There isn’t always a suitable stream but there often are streams with a good drop in the vicinity it seems around here in the mountains. But those drops usually are not within extension chord length.6) There just happens to be a suitable hydro stream source nearby.
The interesting part is that most often the daylight time is when people are up and moving their vehicles. So at night when everyone is sleeping it would be interesting to be able to charge. But solar doesn’t work at night. So hydro could get interesting.Most sites like this will have some solar exposure so installing a "solar carport" would probably be the lowest hassle way to charge, even if it's temporary. That would require much of the Cybertrucks cargo capacity (as would a mini-hydro system) but would be super cool - It would be like having your own personal gas station at your remote site!
But of course there are problems. The prerequisites that you listed are a good start. Additionally there is the need to be within extension chord length of the generator. Also, it is not easy to set up and will require different equipment depending on the exact location. And if it’s too cold or hot the water may not even be flowing. Or if there wasn’t enough moisture this year. Basically reliability is not truly reliable.
But for solar you just need to find sun exposure. And have the hardware with you.
And here is a key point. If you are traveling somewhere, hydroelectric is a very unreliable and impractical source of energy.There are very few places in the lower 48 you cannot take a Cybertruck due to range issues as long as you exercise reasonable trip planning.
But if you are on your own land and it just happens to have he right conditions, and you have put in the planning / work to install a good hydroelectric system, and you have run electricity from your hydroelectric installation to a convenient parking spot for your EV, then hydroelectric could be WAY more convenient / reliable than solar.
I’d love to have a homestead with hydroelectric power. But the chances are slim that will happen. Too many things need to be just right.
