Pollan
- Phil
- Sep 3, 2020
- Dallas, Texas
- Ford 500, Honda Pilot
Can't one simply lower the air suspension to fit in a normal garage.
Who are you asking?Jeez why is your garage so low? Does your garage door only open 3/4th of the way?
Who are you asking?
Sure, what about it?Let's talk about your garage I suppose.
Should be no need; the CT is no taller (or longer or wider) than a common full-size pickup.Can't one simply lower the air suspension to fit in a normal garage.
Just checked the intended parking spot, 8' door & 24' deep. Funny story why the doors are 8' tall. My previous garage door was lower and I broke a few glass camper shell doors when I forgot and backed out without closing the shell glass. New house and the new garage is idiot-proof in that one particular area, I am sure I will find something else to work on given enough rope.Should be no need; the CT is no taller (or longer or wider) than a common full-size pickup.
Let me ask this other garage-preparation question again. (Maybe somebody's seen the prototype close up, or knows if there's a standard with the other Tesla models.)Elon mentioned in one of the interviews that they would adjust the CT dimensions to fit a standard garage.
Its behind the rear driver side wheel well. You can see the port door in photos.Let me ask this other garage-preparation question again. (Maybe somebody's seen the prototype close up, or knows if there's a standard with the other Tesla models.)
At which corner of the CT will the charging port likely be located?
