CompMaster
Can't wait to see Munro's tear down of the new S. To see if they made a structural pack for new S using the 18650 size with the 2170 chemistry. That may give us a bit more of a clear picture on what's next..
lower payload for the tri-motor version wouldn't pass marketing department's approval ¯\_(ツ)_/¯I feel like I am missing something, all three models of the CT are advertised as having a 3500lb payload. But shouldn’t the tri motor with the 500 mile range be less. The extra weight of the motors plus the much bigger battery pack should subtract from the GVWR and equal a smaller payload.
Also if you can make the tri motor go 500 miles why wouldn’t that battery pack be put in the dual and single motor and have an even better range?
This.3500lbs will probably be the max payload which will be the lightest version of the truck just like how the big 3 always advertise the max towing/payload on a truck that nobody will ever buy. crew cabs with all the bells and whislles will always pay a payload price.
Based on 300Whrs/Kg the largest pack will weigh around 1460 lbs and the smallest pack will weigh roughly half. You might reduce the weight on the rear axle by 400 lbs with the smaller pack.You have to be able to move and stop a payload to carry it as well.
The battery will be less than a thousand pounds for a whole battery pack (probably around 500? This is a wild guess) and the additional motor weighs like seventy pounds. So that's a difference of like, two or three passengers.
This difference would matter to a small car, but not to a truck.
...Which is twice the Model 3 and the Cybertruck's battery pack should be even lighter.Based on 300Whrs/Kg...
My understanding is that current 2170 batteries are 260Whr/Kg and the first generation 4860 will be 300. People are extrapolating the curve to show 400 in 5 years but we are not there yet. I am not being snarky but where are you getting numbers in the 500s? Maybe the 260Whr/Kg is for the cheaper LiFe cells for the China models and first gen will be in the mid 300s. Wikipedia says the 2013 era 18650 where 265Wh/Kg. IDK....Which is twice the Model 3 and the Cybertruck's battery pack should be even lighter.
That's battery weight, not pack weight.My understanding is that current 2170 batteries are 260Whr/Kg and...
Now, yes, the Cybertruck packs will be lighter, but maybe only by 50%, maybe more? We don't really know. But additional batteries will weigh much less than to other vehicles. Doubling a structural battery is more like just doubling the cells than doubling the entire pack.The Long Range version carries 4,416 cells arranged in 96 groups of 46, and weighs 1,060 pounds (480 kg) in a 0.40 m³ volume; a density of 150 Wh/kg. Tesla continues to improve the design of the 2170 battery cell...
