How Much will the Tailgate Weigh?
Watch the reveal video. 1 person opened it on stage, while thousands watched him. It was effortless and quick. He took the ramp down in the same fast and easy manor. Then put it up just as easily. Why all the needless hand-wringing?
I went back and watched the video before my first comment. That guy is taller than Elon so I would guess about 6'-4". I agree with you also, wait and see. If it's too damn heavy for soccer moms, Tesla will have a solution.
They seem to like clean lines and minimal design, I suspect the assist springs, Dampers, whatever u call it will be in the bottom, invisible to us.
Chains would be the easiest but would provide no assist whatsoever - but would keep the tailgate from slamming into someone/something and you could sit on it. Dampers would be less easy but would soften the blow in the downward direction but would need a release to close the tailgate and you would still need some kind of stop if you wanted to sit on it. An electric or pneumatic solution would match the truck's design the best and would match lift gate technology. It will be interesting to see what they do. It might take them several iterations to hone in on a solution they like. Look at the Model 3/Y. They keep changing them. Unfortunately not retroactively.
The pick up truck aftermarket disagrees. You can retrofit dampers on a conventional pickup truck tailgate:
Going pneumatic there is underbed room to execute those mechanizations. Plus in the hyper extended ramp-down example, room exists in sailplanes for larger assist.
FullyGrounded
Michael
FL
I like the ramp within the tail gate. The tail gate, when positioned beyond level; becomes part of the ramp. Drop the air suspension to provide the best and safest incline. My main concern about this way to stow the ramp, is what about if you're mudding with your ATV, won't you need to clean it before stowing? You don't want mud and rocks filling your tail gate cavity, or eventually it won't even fit the ramp.
The weight, I will guess at 110lbs
Delusional
Delusional
Phil
Pittsburgh
F-150
Construction
  • #36
Unless I missed one, so far, we have four guesses. Shown in pounds.
Let's get some more please.
168: Me
155: Newton (Or 70 kilos)
80 : rr6013.
110: Fully Grounded
168: Me
80 : rr6013.
110: Fully Grounded
Put me down for 180lbs. if it's all stainless. With an Aluminum ramp I'll say 148lbs
Turtle
Roger
South Carolina
Cyber Truck
I agree, Tesla will make it right! If the competition has dampened or auto lift tailgates so will Tesla! But, guess what? We all will have to wait until the new and final design is revealed. Then you can purchase or get your deposit back.
I hope the reveal happens before we have to make a purchase decision. Would like a little time for the design to get reviewed and talked about so I can make a better final decision.
But I'm also a bit afraid of when the reveal happens. Given the level of pent up demand, I'm guessing that this forum and most likely many others will explode with comment on the final design once it is revealed. I already am spending too much time here with the current level of discourse. After the reveal I may not be able to keep up with all I have to do.
Does @FutureBoy even exist? Who drivels like this? After dropping “Afraid“ fear-mongering then follows immediately with “explode”?
I call BS.
I call BS.
I have been thwarted at times by the existential question of my own existence. So far, the fact that I see others responding to my entreaties does give me a sense of actual existence. But I may be wrong. YMMV.
Turtle
Roger
South Carolina
Cyber Truck
Chuckle , chuckle! Understand!!
Tesla has always done production reveal to insiders first. So we'll get to see lots of them as they got to Tesla-aligned companies first, and then to us.
verinder
verinder
brampton ontario
toyota yaris
truck drniver
It is a truck. I never get people that wouldn’t drive a truck unless it has a damped tailgate. They are ok loading 80 Ib bags of concrete all day but need a damped tailgate. You may as well ask for an automated manicure feature too. consider the extra weight a free exercise feature. Weight reduction is a big design consideration for Tesla. I am sure they will make it as light as they can.
I wouldn’t mind it as is even if it is heavy. If they add the mid gate, the ramp can serve a dual purpose, to be extended in tailgate closed position as a part of a more solid camping contraption.
I agree with this guy... I am sure they have ways to keep it light .
Tim
Model 3 LRPERF
I think the CYBRTRK tailgate will be much heavier than any other tailgate anybody has seen before. I think most of you will agree with me.
The question is: How much will it weigh? I think with the (optional?) slide-out ramp, it will be far over 100 pounds. Possibly approaching 200 pounds. Will it take four guys to safely remove it from it's hinge?
My guess is 168 pounds, but the only reason I chose that number is I hit it on the lottery last week.
What is your guess?
P.S. Maybe this question has been asked before?
I was going to bump this old thread but decided a new thread might be better..
https://www.cybertruckownersclub.co...urb-weight-an-interesting-analysis.963/page-2
Also it’s about strength and lightness, Tesla is going to make it as light as possible to fit the intended use case.
We have to remember the main issue we have around scratches and dents is not that it looks bad. The reason it “looks bad” is the potentiality of rust and deterioration that is likely to occur as a result. Scratches and dents are not going to mean the same thing in a stainless steel vehicle. So as long as the tailgate still functions, dents from prioritising lightness will be inconsequential.
Similar threads
Replies
19
Views
3,221
